Programming .jic to S25FL128S FLASH with Cyclone 10 LP device
I very much doubt there are any 'special characteristics' of that device. I'm pretty confident I'll have used exactly that part before without issue.
Can you read/write to any part of the device from your FPGA? Is it damaged? You suggest it has previously worked as expected...
Cheers,
Alex
Hi Alex,
Thanks for you reply.
I checked the issue with another FPGA board.
1. At first, the jic file can be programmed into the S25FL128S.
2. Then, I execute sector protect operation on S25FL128S with "Generic Serial Flash Interface Intel FPGA IP Core".
3. Then, I failed to program the jic file into S25FL128S, which is expected due to the sector protect operation in step 2.
4. I unprotect the S25FL128S with "Generic Serial Flash Interface Intel FPGA IP Core".
5. Still, no way to download the jic into S25FL128S.
I doubt if some register bits of S25FL128S is locked to prevent the programming operation after step3. Do you have any clue?
Thx so much!
Leo
