14 years agoProfiling total memory usage in Nios II
Hi, everybody! A C program is running on a Nios II processor. At the rate of 100 ns, for instance, I need to catch the total memory the program is using, including there the text memory, the data ...
14 years ago1) If you are worried about memory footprint, it is best to avoid malloc() (ok malloc() is ok - just don't call free()!) then it memory can't run out at inopportune moments.
2) Code, data, bss and other segments sizes can be found from 'objdump -h' or 'size -A' (and other requests) on the final image. 3) Stack use is more problematic. If you have no recursive calls and no calls via function pointers it is possible to write a C program to analise the generated code to sort out the call graph and stack level at each call. I process the output of 'gcc -S -fverbose-asm ...' in order to statically count the worst case execution time of my code (there are no function calls in it!) I also use a few asm statements to mark some paths as 'to be ignored'.
