13 years ago
Problems with installing Nios2 Linux
I am attempting to install the Nios2 Linux development tools on a Centos 6.3 based system.
I am somewhat confused by the instructions (on alteras wiki: Install_Nios_II_Linux). They indicate that the test-nios2 branch is the current branch of the kernel, but the nios2-linux-20100621.tar doesn't come automatically configured for this branch. The instructions also indicate that the current kernel uses the Devicetree approach to configuring the kernel for hardware, though, if I build with the test-nios2 branch, I have to use the vendor_hwselect mechanism
Can someone tell me what the current branch is (test-nios2 or nios2mmu under linux-2.6 and test-nios2 or trunk under uClinux-dist) and what the current hardware customization mechanism is (vendor_hwselect, devicetree or sopc generated header)?
Also, assuming that the current hardware customization is something other than vendor_hwselect, how do I configure things to get it?
Thanks in advance. I'm trying to get ready to use this in a college class that starts at the end of September.
D.W. Lynn
For reference, Here is what I did, working from the Install_Nios_II_Linux instructions on the wiki, specifically using nios2-linux-20100621.tar.
The tool-chain build step first complained:
/home/lynnd/nios2-linux/toolchain-build/u-boot.mk:11: Board not defined! Using EP1S10 as default.
and later fails with the following:
home/lynnd/nios2-linux/uClibc'
make[2]: `conf' is up to date.
CC libpthread/linuxthreads.old/cancel.o
In file included from ./include/sys/syscall.h:34,
from libpthread/linuxthreads.old/restart.h:16,
from libpthread/linuxthreads.old/cancel.c:23:
./include/bits/syscalls.h:10:23: asm/traps.h: No such file or directory
make[1]: *** [libpthread/linuxthreads.old/cancel.o] Error 1
make[1]: Leaving directory `/home/lynnd/nios2-linux/uClibc'
make: *** [/home/lynnd/nios2-linux/toolchain-build/../uClibc/lib/libc.a] Error 2
So, I switched to the prebuild binary toolchain, which worked. Then I attempted to make the kernel per the instructions using the make menuconfig process. There were lots of undefaulted options. On the final kernel make, I had to do "make CROSS-COMPILE=nios2-linux- since the default CROSS_COMPILE was nios2-linux-gnu-
and that's not how the binary toolchain installed and I couldn't find the CROSS_COMPILE option in make menuconfig kernel customization.
However, I still got the following error:
/home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S: Assembler messages:
/home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:542: Error: expecting control register
/home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:542: Error: unknown register r6
make[3]: *** [arch/nios2/kernel/entry.o] Error 1
Following some hints elsewhere in the forum, I removed the nios2-linux/ directory completely and untarred nios2-linux-20100621.tar again (to start fresh). Then,
before doing the ./checkout step, I did "git checkout test-nios2 -f" in both the uClinux and the linux-2.6 directories.
Now the kernel make process succeeds even though it uses the vendor_hwselect mechanism. Note that the documentation for Devicetree (linux-2.6/Documentation/devicetree) does not exist in the test-nios2 branch and make menuconfig in this branch does not give options for using the Device tree approach (that I could find).
    --- Quote Start ---
    The files which are indicated by the tag ETC_FILES-y
    ETC_FILES-y =
        filesystems group issue mdev.conf mime.types modprobe.conf motd
        passwd profile rc TZ nsswitch.conf syslog.conf sc.cfg
    are copied from your /nios2-linux/uClinux-dist/vendors/Altera/common directory ro /etc.
        for f in $(ETC_FILES-y) ; do
            $(ROMFSINST) ../common/$$f /etc/$$f ;
        done ;
    So you must create the 'syslog.conf' file (which is used for rsyslogd) and 'sc.cfg' (I don't know what's this).
    And you have 4 errors which are caused by your 'rc' script file.
    1) ifconfig: SIOCSIFADDR: No such device
    are caused by the lines 86 and 87.
    #  Set up eth1 IP address
    ifconfig eth0 192.168.11.4 up
    ifconfig eth1 192.168.1.4 up
    2) cp: can't stat '/etc/sc.cfg': No such file or directory
    is caused by the line 93.
    #  Move SoftClock config file to where it is accessed by application, location is hardcoded in application
    cp /etc/sc.cfg /var/log
    3) insmod: can't insert '/usr/sbin/fpga.ko': No such file or directory
    Usage: mknod [-m MODE] NAME TYPE MAJOR MINOR
    are caused by the lines 96 and 101.
    # Set up device driver, insert kernel module
    insmod /usr/sbin/fpga.ko#  create device node using major number /proc/devices table
    CURRWD=`pwd`
    cd /dev
    MAJOR_NUM=$(awk 'BEGIN {FS=" "}; {if ($2 == "fpgasymm") print $1;}' /proc/devices)
    mknod -m=777 fpgasymm c $MAJOR_NUM 0
    cd $CURRWD
    4) sh: can't execute 'rsyslogd': No such file or directory
    is caused by the line 105.
    #  start rsyslogd daemon
    rsyslogd -n -m0 -f /etc/syslog.conf &
    If you don't require these, please delete or comment out those lines and recompile the kernel.
    Kazu
    --- Quote End ---
    Now I understsand better. I updated my design in Qsys and added a second timer. Picture https://i.stack.imgur.com/2jywn.png
    If I try and use that design I get this error msg
    Linux version 3.5.0-rc4-01329-ga227997-dirty (developer@1604) (gcLinux version 3.5.0-rc4-01329-ga227997-dirty (developer@1604) (gcc version 4.1.2)# 810 Sat Apr 1 14:23:20 CEST 2017
    bootconsole  enabled
    early_console initialized at 0xe8001440
    ERROR: Nios II MUL different for kernel and DTS
    Unable to handle kernel NULL pointer dereference at virtual address 00000000
    ea = c0238094, ra = c0238078, cause = 15
    Kernel panic - not syncing: Oops
    What does it mean?
    --- Quote Start ---
    bootconsole  enabled
    What does it mean?
    --- Quote End ---
    Maybe, you have the file '/arch/nios2/hernel/cpuinfo.c'.
    http://lxr.free-electrons.com/source/arch/nios2/kernel/cpuinfo.c
      32# define err_cpu(x)
      33         pr_err("ERROR: Nios II " x " different for kernel and DTS\n")
      75         if (IS_ENABLED(CONFIG_NIOS2_HW_MUL_SUPPORT) && !cpuinfo.has_mul)
      76                 err_cpu("MUL");
    Did you setup 'CONFIG_NIOS2_HW_MUL_SUPPORT'? And also please check the contents of your dst file.
    Kazu
