14 years agoProblems with installing Nios2 Linux
I am attempting to install the Nios2 Linux development tools on a Centos 6.3 based system. I am somewhat confused by the instructions (on alteras wiki: Install_Nios_II_Linux). They indicate tha...
9 years ago --- Quote Start --- Hi, Of course, you did . Copying 'sc.cfg' file is written in the 'rc' script file or somewhere ? Kazu --- Quote End --- It's the Makefile that assumes the sc.cfg and syslog.conf I don't know what do to about it. If I remove those two variables then it builds, but they should be somewhere shouldn't they? The other changes was because of deprecation in Perl about define statement and a header in serve_image.c that I had to comment out but I don't know what I'm doing.
## Makefile -- Build instructions for Altera/nios2#
.EXPORT_ALL_VARIABLES:
include $(LINUX_CONFIG)
include $(CONFIG_CONFIG)
ROMFS_DIRS-y = bin etc etc/dhcpc home lib mnt proc sys usr var root home tmp etc/config var/run var/lib/misc usr/sbin
ETC_FILES-y =
filesystems group issue mdev.conf mime.types modprobe.conf motd
passwd profile rc TZ nsswitch.conf syslog.conf sc.cfg
WEB_FILES-y =
ETC_FILES-$(CONFIG_NET) += hosts host.conf protocols services
ETC_FILES-$(CONFIG_USER_INETD_INETD) += inetd.conf
ETC_FILES-$(CONFIG_USER_BUSYBOX_INETD) += inetd.conf
ROMFS_DIRS-$(CONFIG_USER_BUSYBOX_FTPD) += home/ftpd
ROMFS_DIRS-$(CONFIG_USER_BUSYBOX_TFTPD) += home/tftpboot
ROMFS_DIRS-$(CONFIG_USER_BUSYBOX_HTTPD) += home/httpd home/httpd/cgi-bin
WEB_FILES-$(CONFIG_USER_BUSYBOX_HTTPD) += index.html favicon.ico
ROMFS_DIRS-$(CONFIG_USER_BOA_SRC_BOA) += home/httpd home/httpd/cgi-bin etc/boa var/log/boa
ETC_FILES-$(CONFIG_USER_BOA_SRC_BOA) += boa.conf
WEB_FILES-$(CONFIG_USER_BOA_SRC_BOA) += boa.conf index.html favicon.ico
MKFS_JFFS2_FLAGS = -l -p -e 128
all::
romfs.post:: romfs.shared.libs
romfs::
mkdir -p $(ROMFSDIR)
cd $(ROMFSDIR) && mkdir -p $(ROMFS_DIRS-y)
chmod 1777 $(ROMFSDIR)/tmp
$(ROMFSINST) -s bin /sbin
$(ROMFSINST) /etc/inittab
set -e ;
for f in $(ETC_FILES-y) ; do
$(ROMFSINST) ../common/$$f /etc/$$f ;
done ;
for f in $(WEB_FILES-y) ; do
$(ROMFSINST) ../common/$$f /home/httpd/$$f ;
done
$(ROMFSINST) -e CONFIG_USER_BUSYBOX_FTPD
-a "21 stream tcp nowait root ftpd ftpd -w /home/ftpd" /etc/inetd.conf
$(ROMFSINST) -e CONFIG_USER_BUSYBOX_TELNETD
-a "23 stream tcp nowait root telnetd telnetd -i" /etc/inetd.conf
$(ROMFSINST) -e CONFIG_USER_BUSYBOX_TFTPD
-a "69 dgram udp nowait root tftpd tftpd -c /home/tftpboot" /etc/inetd.conf
$(ROMFSINST) -e CONFIG_USER_BUSYBOX_HTTPD
-a "80 stream tcp nowait root httpd httpd -i -h /home/httpd" /etc/inetd.conf
echo "$(VERSIONSTR) -- `date`" > $(ROMFSDIR)/etc/version
ifeq ($(CONFIG_BLACKFIN_INSTALL_UCLINUX_CONFIG),y)
gzip -9c $(ROOTDIR)/config/.config > $(ROMFSDIR)/root/uclinux-config.gz
gzip -9c $(ROOTDIR)/.config > $(ROMFSDIR)/root/vendor-board-config.gz
endif
ifeq ($(CONFIG_USER_DEV_DYNAMIC),y)
DEVICE_TABLE = device_table-min.txt
else
ifeq ($(CONFIG_USER_BUSYBOX_MDEV),y)
$(warning )
$(warning You have busybox's mdev enabled. The static device tree will be)
$(warning overridden during boot by a tmpfs in /dev.)
$(warning )
endif
DEVICE_TABLE = device_table.txt
endif
# these targets can be found in Altera/vendor.mak
image::
mkdir -p $(IMAGEDIR)
rm -rf $(IMAGEDIR)/*
$(MAKE) image.rootfs.all
$(MAKE) image.kernel.all
$(MAKE) image.uimage.all
$(MAKE) image.zimage.all
clean::
.PHONY: all clean image romfs
include ../../$(CONFIG_VENDOR)/vendor.mak
