14 years agoProblems with installing Nios2 Linux
I am attempting to install the Nios2 Linux development tools on a Centos 6.3 based system.
I am somewhat confused by the instructions (on alteras wiki: Install_Nios_II_Linux). They indicate that the test-nios2 branch is the current branch of the kernel, but the nios2-linux-20100621.tar doesn't come automatically configured for this branch. The instructions also indicate that the current kernel uses the Devicetree approach to configuring the kernel for hardware, though, if I build with the test-nios2 branch, I have to use the vendor_hwselect mechanism Can someone tell me what the current branch is (test-nios2 or nios2mmu under linux-2.6 and test-nios2 or trunk under uClinux-dist) and what the current hardware customization mechanism is (vendor_hwselect, devicetree or sopc generated header)? Also, assuming that the current hardware customization is something other than vendor_hwselect, how do I configure things to get it? Thanks in advance. I'm trying to get ready to use this in a college class that starts at the end of September. D.W. Lynn For reference, Here is what I did, working from the Install_Nios_II_Linux instructions on the wiki, specifically using nios2-linux-20100621.tar. The tool-chain build step first complained: /home/lynnd/nios2-linux/toolchain-build/u-boot.mk:11: Board not defined! Using EP1S10 as default. and later fails with the following: ... home/lynnd/nios2-linux/uClibc' make[2]: `conf' is up to date. CC libpthread/linuxthreads.old/cancel.o In file included from ./include/sys/syscall.h:34, from libpthread/linuxthreads.old/restart.h:16, from libpthread/linuxthreads.old/cancel.c:23: ./include/bits/syscalls.h:10:23: asm/traps.h: No such file or directory make[1]: *** [libpthread/linuxthreads.old/cancel.o] Error 1 make[1]: Leaving directory `/home/lynnd/nios2-linux/uClibc' make: *** [/home/lynnd/nios2-linux/toolchain-build/../uClibc/lib/libc.a] Error 2 So, I switched to the prebuild binary toolchain, which worked. Then I attempted to make the kernel per the instructions using the make menuconfig process. There were lots of undefaulted options. On the final kernel make, I had to do "make CROSS-COMPILE=nios2-linux- since the default CROSS_COMPILE was nios2-linux-gnu- and that's not how the binary toolchain installed and I couldn't find the CROSS_COMPILE option in make menuconfig kernel customization. However, I still got the following error: /home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S: Assembler messages: /home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:542: Error: expecting control register /home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:542: Error: unknown register r6 make[3]: *** [arch/nios2/kernel/entry.o] Error 1 Following some hints elsewhere in the forum, I removed the nios2-linux/ directory completely and untarred nios2-linux-20100621.tar again (to start fresh). Then, before doing the ./checkout step, I did "git checkout test-nios2 -f" in both the uClinux and the linux-2.6 directories. Now the kernel make process succeeds even though it uses the vendor_hwselect mechanism. Note that the documentation for Devicetree (linux-2.6/Documentation/devicetree) does not exist in the test-nios2 branch and make menuconfig in this branch does not give options for using the Device tree approach (that I could find).32 Replies
'entry.S: Error: unknown register r6'
makes me worried too. - Altera_Forum
All you need to instal nios2-linux is to install following packages: git-all git-gui make gcc ncurses-devel bison byacc flex gawk gettext ccache zlib-devel gtk2-devel lzo-devel pax-utilslibglade2-devel uboot-tools
Next you need download from git all needed sources: git clone -b trunk git://sopc.et.ntust.edu.tw/git/uClinux-dist.git git clone git://sopc.et.ntust.edu.tw/git/toolchain-mmu.git git clone git://sopc.et.ntust.edu.tw/git/linux-2.6.git git clone git://sopc.et.ntust.edu.tw/git/tools.git Now you need to set eviroment path in .bashrc file. My looks like follows: --------------------------------------------------------------- QUARTUS=/home/kamil/altera/12.1/quartus export QUARTUS NIOS2EDS=/home/kamil/altera/12.1/nios2eds export NIOS2EDS SOPC_KIT_NIOS2=/home/kamil/altera/12.1/nios2eds export SOPC_KIT_NIOS2 NIOS2LINUX=/home/kamil/uClinux export NIOS2LINUX PATH=$QUARTUS/bin:$QUARTUS/sopc_builder/bin:$NIOS2EDS:$NIOS2LINUX/toolchain-mmu/x86-linux2/bin:/usr/bin:$PATH export PATH --------------------------------------------------------------------------- In that way I have path for every tool from Altera like also for toolchain for nios2-uclinux. Last step is to make sopc2dts tool. Just do "make" command in /tools/sopc2dts/ location (for that you need jdk-devel package) And that is all. Now you can play with linux on your nios2 boards :) - Altera_Forum
--- Quote Start --- All you need to instal nios2-linux is to install following packages: git-all git-gui make gcc ncurses-devel bison byacc flex gawk gettext ccache zlib-devel gtk2-devel lzo-devel pax-utilslibglade2-devel uboot-tools Next you need download from git all needed sources: git clone -b trunk git://sopc.et.ntust.edu.tw/git/uClinux-dist.git git clone git://sopc.et.ntust.edu.tw/git/toolchain-mmu.git git clone git://sopc.et.ntust.edu.tw/git/linux-2.6.git git clone git://sopc.et.ntust.edu.tw/git/tools.git Now you need to set eviroment path in .bashrc file. My looks like follows: --------------------------------------------------------------- QUARTUS=/home/kamil/altera/12.1/quartus export QUARTUS NIOS2EDS=/home/kamil/altera/12.1/nios2eds export NIOS2EDS SOPC_KIT_NIOS2=/home/kamil/altera/12.1/nios2eds export SOPC_KIT_NIOS2 NIOS2LINUX=/home/kamil/uClinux export NIOS2LINUX PATH=$QUARTUS/bin:$QUARTUS/sopc_builder/bin:$NIOS2EDS:$NIOS2LINUX/toolchain-mmu/x86-linux2/bin:/usr/bin:$PATH export PATH --------------------------------------------------------------------------- In that way I have path for every tool from Altera like also for toolchain for nios2-uclinux. Last step is to make sopc2dts tool. Just do "make" command in /tools/sopc2dts/ location (for that you need jdk-devel package) And that is all. Now you can play with linux on your nios2 boards :) --- Quote End --- I get the same incomprehensible error
I already tried everything./home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S: Assembler messages: /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: unknown register r5 /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:546: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:546: Error: unknown register r6 make: *** Error 1 make: *** Error 2 make: *** Error 2 make: Leaving directory `/home/developer/altera/nios2-linux/linux-2.6' make: *** Error 1 - Altera_Forum
--- Quote Start --- I get the same incomprehensible error
I already tried everything. --- Quote End --- Do you have any destroied files under the directory "arch/nios2/include/asm" ? Please check out 'entry.h’ or 'system.h' especially for the instruction 'rdctl' and 'wrctl'. Kazu/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S: Assembler messages: /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: unknown register r5 /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:546: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:546: Error: unknown register r6 make: *** Error 1 make: *** Error 2 make: *** Error 2 make: Leaving directory `/home/developer/altera/nios2-linux/linux-2.6' make: *** Error 1 - Altera_Forum
--- Quote Start --- Hi, Do you have any destroied files under the directory "arch/nios2/include/asm" ? Please check out 'entry.h’ or 'system.h' especially for the instruction 'rdctl' and 'wrctl'. Kazu --- Quote End --- In entry.h, it seems normal
I wonder if there could be something wrong with my toolchain? I use the pre-built toolchain and I first didn't include `nios2-linux/toolchain-mmu/x86-linux2/bin` If I do include the aforementioned path then I get a different error. I installed the pre-built toolchain in `opt/nios2/bin` in entry.h the wrctl instruction is just#ifdef CONFIG_MMU rdctl r24,estatus
Any idea what I could do to make it build cleanly? My PATH iswrctl estatus,r24
I also installed gcc 4.2 with the multilib for 4.2. I think I did everything right, still it won't build.echo $PATH /usr/bin:/home/developer/eclipse/java-neon/eclipse:/home/developer/altera/nios2-linux/toolchain-mmu/x86-linux2/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/developer/Downloads/NuSMV-2.6.0-Linux/bin:/snap/bin:/opt/nios2/bin - Altera_Forum
--- Quote Start --- In entry.h, it seems normal
I also installed gcc 4.2 with the multilib for 4.2. I think I did everything right, still it won't build. --- Quote End --- The messageecho $PATH /usr/bin:/home/developer/eclipse/java-neon/eclipse:/home/developer/altera/nios2-linux/toolchain-mmu/x86-linux2/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/developer/Downloads/NuSMV-2.6.0-Linux/bin:/snap/bin:/opt/nios2/bin
is made in the function/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: expecting control register
of file "tc-nios2.c". So I think that you are calling the genuine nios2's 'gas'. Please try to compile the 'entry.S' only, by evoking the 'nios2-***-gcc' or 'nios2-***-as' directly ? Kazu/* The function consume_arg takes a pointer into a string of instruction tokens (args) and a pointer into a string representing the expected sequence of tokens and separators. It checks whether the first argument in argStr is of the expected type, throwing an error if it is not, and returns the pointer argStr. */ char * nios2_consume_arg (char *argStr, const char *argType) { char *temp; int regno = -1; switch (*argType) { case 'c': if (strncmp (argStr, "ctl", strlen ("ctl")) != 0 && strncmp (argStr, "cpuid", strlen ("cpuid")) != 0 && strncmp (argStr, "status", strlen ("status")) != 0 && strncmp (argStr, "estatus", strlen ("estatus")) != 0 && strncmp (argStr, "bstatus", strlen ("bstatus")) != 0 && strncmp (argStr, "ienable", strlen ("ienable")) != 0 && strncmp (argStr, "ipending", strlen ("ipending")) != 0 && strncmp (argStr, "exception", strlen ("exception")) != 0 && strncmp (argStr, "pteaddr", strlen ("pteaddr")) != 0 && strncmp (argStr, "tlbacc", strlen ("tlbacc")) != 0 && strncmp (argStr, "tlbmisc", strlen ("tlbmisc")) != 0 && strncmp (argStr, "fstatus", strlen ("fstatus")) != 0 && strncmp (argStr, "config", strlen ("config")) != 0 && strncmp (argStr, "mpubase", strlen ("mpubase")) != 0 && strncmp (argStr, "mpuacc", strlen ("mpuacc")) != 0 && strncmp (argStr, "badaddr", strlen ("badaddr")) != 0) { as_bad (_("expecting control register")); } break; - Altera_Forum
--- Quote Start --- Hi, The message
of file "tc-nios2.c". So I think that you are calling the genuine nios2's 'gas'. Please try to compile the 'entry.S' only, by evoking the 'nios2-***-gcc' or 'nios2-***-as' directly ? Kazu --- Quote End --- This is what happens/* The function consume_arg takes a pointer into a string of instruction tokens (args) and a pointer into a string representing the expected sequence of tokens and separators. It checks whether the first argument in argStr is of the expected type, throwing an error if it is not, and returns the pointer argStr. */ char * nios2_consume_arg (char *argStr, const char *argType) { char *temp; int regno = -1; switch (*argType) { case 'c': if (strncmp (argStr, "ctl", strlen ("ctl")) != 0 && strncmp (argStr, "cpuid", strlen ("cpuid")) != 0 && strncmp (argStr, "status", strlen ("status")) != 0 && strncmp (argStr, "estatus", strlen ("estatus")) != 0 && strncmp (argStr, "bstatus", strlen ("bstatus")) != 0 && strncmp (argStr, "ienable", strlen ("ienable")) != 0 && strncmp (argStr, "ipending", strlen ("ipending")) != 0 && strncmp (argStr, "exception", strlen ("exception")) != 0 && strncmp (argStr, "pteaddr", strlen ("pteaddr")) != 0 && strncmp (argStr, "tlbacc", strlen ("tlbacc")) != 0 && strncmp (argStr, "tlbmisc", strlen ("tlbmisc")) != 0 && strncmp (argStr, "fstatus", strlen ("fstatus")) != 0 && strncmp (argStr, "config", strlen ("config")) != 0 && strncmp (argStr, "mpubase", strlen ("mpubase")) != 0 && strncmp (argStr, "mpuacc", strlen ("mpuacc")) != 0 && strncmp (argStr, "badaddr", strlen ("badaddr")) != 0) { as_bad (_("expecting control register")); } break;$ nios2-linux-uclibc-gcc linux-2.6/arch/nios2/kernel/entry.S linux-2.6/arch/nios2/kernel/entry.S:35:23: linux/sys.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:36:27: linux/linkage.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:37:29: asm/asm-offsets.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:38:28: asm/asm-macros.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:39:29: asm/thread_info.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:42:23: asm/entry.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:44:27: asm/processor.h: No such file or directory - Altera_Forum
--- Quote Start --- This is what happens
--- Quote End --- Please try$ nios2-linux-uclibc-gcc linux-2.6/arch/nios2/kernel/entry.S linux-2.6/arch/nios2/kernel/entry.S:35:23: linux/sys.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:36:27: linux/linkage.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:37:29: asm/asm-offsets.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:38:28: asm/asm-macros.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:39:29: asm/thread_info.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:42:23: asm/entry.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:44:27: asm/processor.h: No such file or directory
. And I think that you should better learn compiler switches. Kazunios2-linux-uclibc-gcc -c -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S - Altera_Forum
Thanks for the help but I'm only getting more and more errors.
$ nios2-linux-uclibc-gcc -c -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include -I/home/developer/altera/nios2-linux/uClinux-dist/linux-2.6.x/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h: Assembler messages: /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:82: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:83: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:84: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:85: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:86: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:87: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:88: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:89: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:90: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:91: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:92: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:93: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:94: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:95: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:96: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:97: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:98: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:99: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:100: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:101: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:102: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:103: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:105: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:107: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:111: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:117: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:118: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:119: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:120: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:121: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:122: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:123: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:124: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:125: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:126: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:127: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:128: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:129: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:62: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:63: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:66: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:67: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:69: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:71: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:90: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:92: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:95: Error: unrecognised instruction static /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:96: Error: junk at end of line, first unrecognized character is `{' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:97: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:100: Error: unrecognised instruction static /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:101: Error: junk at end of line, first unrecognized character is `{' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:102: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:107: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:112: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:124: Error: unrecognised instruction save_all /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: unknown register r5 ... - Altera_Forum
--- Quote Start --- Thanks for the help but I'm only getting more and more errors.
--- Quote End --- Please add -D name option switches like$ nios2-linux-uclibc-gcc -c -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include -I/home/developer/altera/nios2-linux/uClinux-dist/linux-2.6.x/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h: Assembler messages: /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:82: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:83: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:84: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:85: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:86: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:87: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:88: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:89: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:90: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:91: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:92: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:93: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:94: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:95: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:96: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:97: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:98: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:99: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:100: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:101: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:102: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:103: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:105: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:107: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:111: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:117: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:118: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:119: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:120: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:121: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:122: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:123: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:124: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:125: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:126: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:127: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:128: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:129: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:62: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:63: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:66: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:67: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:69: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:71: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:90: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:92: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:95: Error: unrecognised instruction static /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:96: Error: junk at end of line, first unrecognized character is `{' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:97: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:100: Error: unrecognised instruction static /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:101: Error: junk at end of line, first unrecognized character is `{' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:102: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:107: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:112: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:124: Error: unrecognised instruction save_all /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: unknown register r5 ...
. Some include files are used as mixed C and assembly codes. So there is the# ifndef __ASSEMBLY__ macro likenios2-linux-uclibc-gcc -c -D __ASSEMBLY__ -D __KERNEL__ -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include -I/home/developer/altera/nios2-linux/uClinux-dist/linux-2.6.x/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S
. Kazu14# define _ASM_NIOS2_PTRACE_H 15 16# include <uapi/asm/ptrace.h> 17 18 /* This struct defines the way the registers are stored on the 19 stack during a system call. */ 20 21# ifndef __ASSEMBLY__ 22 struct pt_regs { 23 unsigned long r8; /* r8-r15 Caller-saved GP registers */ 24 unsigned long r9; 25 unsigned long r10; 26 unsigned long r11; 27 unsigned long r12; 28 unsigned long r13;
