20 years agoproblems with Flash by redboot on eCos with NIOS2
Hello, I tryed to make reboot working for StratixII Board with NIOSII Processor. Redboot permanently failed on detecting the flash device correctly. As it turns out, the flash detection ro...
20 years agoHello,
I tryed some more out and came now to the conclusion that it cannot be some dcache problem of the volatile pointer, because: - The Flash Base Address ( CYGNUM_FLASH_BASE ) has allready the 31 Bit set (which should tell nios2/f cores to bypass cache -> thanks to you, smcnutt) - I'm tryed also on nios2/s core, which does not have dcache I now think, that the real problem is, that the flash is not addressed in right mode (can be 8 bit or 16 bit). In my testprogramm, i did a 8 bit access, which succeed, but in redboot code, it seems, it does a 16 bit access, when i print out the access addresses. The define constant _16AS8 is set to 0, which switches access mode to 16 Bit, as I suppose. To reproduce the problem, i tryed 16bit access in my test programm, and it fails to, nearly the same as redboot - so wide ok. So i manually set accessmode to 8 bit (in sourcecode) and hope that it whould fix my problem with red boot... but now redboot crashes (and restarts), exactly behind the line, were the read_id command is written to the flash. Curiously, my testprogramm with same code, does not. Anyone an idea? Best regards, Marek
