20 years agoproblems with Flash by redboot on eCos with NIOS2
Hello, I tryed to make reboot working for StratixII Board with NIOSII Processor. Redboot permanently failed on detecting the flash device correctly. As it turns out, the flash detection ro...
20 years agoThank you a lot for the advice, this was something i didnt know yet
So, I just tried out the compiler switches with my test program and -mbypass-cache and -mno-cache-volatile made the pointer operations work like io-instructions. For unknown reason, -mno-bypass-cache did not success. But within my test-program, it works. But when adding this options to compiler options for building redboot, * i was really wondering * it did not work... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif I tried to modify the flash_driver function flash_query(void* data) to make sure and replaced all direct io operations... i thought, this should work for sure, but i don't know why the hell, but it doesn't http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif...
// Marek: made some helper macros# if (_16AS8 == 0)# define FIO_WR(ADDR, DATA) HAL_WRITE_UINT8(CYGNUM_FLASH_BASE + ADDR, DATA)# define FIO_RD(ADDR, VALUE) HAL_READ_UINT8(CYGNUM_FLASH_BASE + ADDR, VALUE)# else# define FIO_WR(ADDR, DATA) HAL_WRITE_UINT16(CYGNUM_FLASH_BASE + ADDR, DATA)# define FIO_RD(ADDR, VALUE) HAL_READ_UINT16(CYGNUM_FLASH_BASE + ADDR, VALUE)# endif
# define FIO_S1_WR( DATA ) FIO_WR( FLASH_Setup_Addr1 , DATA)# define FIO_S2_WR( DATA ) FIO_WR( FLASH_Setup_Addr2 , DATA)
void
//volatile flash_data_t *ROM;
//volatile flash_data_t *f_s1, *f_s2;
flash_data_t* id = (flash_data_t*) data;
flash_data_t w,w2;
long timeout = CYGNUM_FLASH_TIMEOUT_QUERY;
//ROM = (flash_data_t*) CYGNUM_FLASH_BASE;
//f_s1 = FLASH_P2V(ROM+FLASH_Setup_Addr1);
//f_s2 = FLASH_P2V(ROM+FLASH_Setup_Addr2);
// *f_s1 = FLASH_Reset;
FIO_S1_WR(FLASH_Reset);
// w = *(FLASH_P2V(ROM));
FIO_RD(0, w);
// *f_s1 = FLASH_Setup_Code1;
FIO_S1_WR(FLASH_Setup_Code1);
// *f_s2 = FLASH_Setup_Code2;
FIO_S2_WR(FLASH_Setup_Code2);
// *f_s1 = FLASH_Read_ID;
FIO_S1_WR(FLASH_Read_ID);
id = -1;
id = -1;
// Manufacturers' code
// id = *(FLASH_P2V(ROM+FLASH_VendorID_Addr));
FIO_RD(FLASH_VendorID_Addr, id);
// Part number
// id = *(FLASH_P2V(ROM+FLASH_DeviceID_Addr));
FIO_RD(FLASH_DeviceID_Addr, id);
// id = *(FLASH_P2V(ROM+FLASH_DeviceID_Addr2));
FIO_RD(FLASH_DeviceID_Addr2, id);
// id = *(FLASH_P2V(ROM+FLASH_DeviceID_Addr3));
FIO_RD(FLASH_DeviceID_Addr3, id);
// *(FLASH_P2V(ROM)) = FLASH_Reset;
FIO_WR(0, FLASH_Reset);
// Stall, waiting for flash to return to read mode.
FIO_RD(0,w2);
while ((--timeout != 0) && (w != w2/* *(FLASH_P2V(ROM))*/))
FIO_RD(0,w2);
} Did I something wrong?? The nearly same code works in my testing program ... Note: I put a look into the source of ecos 2.01 and found that someone already tried to fix that problem by using hal_dcache_xxxx in a function that wrapp's flash_query. But this depends on that the prozessor is able to switch dcache'ing on/off, which the NIOS prozessor isn't able to. So these Macros actually do nothing when build for NIOS. void
int cache_on;
HAL_DCACHE_IS_ENABLED(cache_on);
if (cache_on) {
HAL_DCACHE_SYNC();
HAL_DCACHE_DISABLE();
_flash_query(data);
if (cache_on) {
HAL_DCACHE_ENABLE();
} I currently give up trying to build redboot and wonder, if all people have such problems, when trying nios with redboot or if i'm just an anomalie... Regards, Marek PS: Sorry for posting much code, i hope it helps more than ti does struggeling you
