20 years agoProblems with EPCS controller
Greetings, I am using SOPC builder to build a system that contains an EPCS controller. I am running a bare bones program to talk to the EPCS part natively using the functions specified i...
20 years agoLook to the sources of epcs controller...
I has the same problem too - i solve it when i find in epcs_controller.v file string where i saw the switch - it menas if you set address where bit 8 is 1 - you can access to epcs chip if bit 8 is 0 you can read only boot rom onchip memory. If you want to get more details let me know. I can send to you my sources for epcs
