16 years agoProblems with creating a Nios II Application and BSP from Template in Eclipse
OK, I know I'm bleeding edge here (or maybe not so much). I'm relatively new with using the Nios II Design Suite, though I've used Quartus with several other Altera boards. I probably did one...
16 years agoHappy to see that the solution still helps ! :-)
For information, it has now been added in the official NIOS EDS Errata sheet since May. See "Nios II Options Do Not Appear in Eclipse " at : http://www.altera.com/literature/rn/rn_nios2eds.pdf Bye.
