16 years agoProblems with creating a Nios II Application and BSP from Template in Eclipse
OK, I know I'm bleeding edge here (or maybe not so much). I'm relatively new with using the Nios II Design Suite, though I've used Quartus with several other Altera boards. I probably did one...
16 years ago --- Quote Start --- Thanks to Pantxoa - it does work! --- Quote End --- My thanks to you as well! I was having exactly this problem and had uninstalled and reinstalled EVERYTHING only to find it failed in the same way. This time after uninstalling NiosII EDS 9.1 I found and deleted all those extraneous Nios II EDS files. Now after installing Nios II EDS 9.1 again the SBT for Eclipse works correctly for the first time ever. Now I can get my project started!
