16 years agoProblems with creating a Nios II Application and BSP from Template in Eclipse
OK, I know I'm bleeding edge here (or maybe not so much). I'm relatively new with using the Nios II Design Suite, though I've used Quartus with several other Altera boards. I probably did one...
16 years agowow, if only i had checked the forums earlier. ive had the same problem for 3months!! I found a way to work around it. apparently if you guys see under the nios folder, there is another subfolder called legacy nios or something, thats the IDE used in the old nios version.
ive been using that for quite a while now ever since my eclipse decided to dissociate itself from nios thanks a lot!
