16 years agoProblems with creating a Nios II Application and BSP from Template in Eclipse
OK, I know I'm bleeding edge here (or maybe not so much). I'm relatively new with using the Nios II Design Suite, though I've used Quartus with several other Altera boards. I probably did one...
16 years agoAlso double check that your perspective is set to "NIOS II" since I believe the default is C/C++.
