16 years agoProblems with creating a Nios II Application and BSP from Template in Eclipse
OK, I know I'm bleeding edge here (or maybe not so much). I'm relatively new with using the Nios II Design Suite, though I've used Quartus with several other Altera boards. I probably did one...
16 years agoAfter uninstalling Nios II EDS, I indeed found some Eclipse files and folders remaining. I manually deleted them, then installed back Nios II EDS and I finally got the "nios ii application and bsp from template" back :). That probably was a problem of corrupted Eclipse.
Thanks Pantxoa for your answer, and good luck Katchins ! ;)
