16 years agoProblems with creating a Nios II Application and BSP from Template in Eclipse
OK, I know I'm bleeding edge here (or maybe not so much). I'm relatively new with using the Nios II Design Suite, though I've used Quartus with several other Altera boards. I probably did one...
16 years agoHi katchins.
Unfortunately, I do not have an answer to your problem. In fact, I'm facing the same issue than you are, which is that after installing Quartus II 9.1, I can't get the "Nios II Application and BSP from Template" option when creating a Project with Eclipse. I'll add that I work with Windows XP, which probably means that the issue may not be platform related. Removing, re-installing, repairing both Quartus and Nios II EDS didn't resolve anything. I'd really appreciate any hint or idea on how to get that menu back. Tthegarde
