9 years agoProblems downloading to NIOS II / Verification fails
Hello I am trying to interface the SD RAM on a DE0 board to a NIOS II. I have carefully followed the steps required to set up the SD RAM controller to use the IS42S16400J. Unfortunately when I...
9 years agoHi, Andrew,
Ok, I it seems understood your problem with screenshots: I have 4K display and whole qsys diagram is visible, whereas on ordinary displays it's impossible. Concerning your main problem, I think you should ask Altera for support your device with your Quartus version. But before can you check some basic things: warning from compiler reports, especially from TimeQuest one .... as I didn't see a constraint file (.sdc extension) in your design folder. At least constraint on system clock must be present. Regards. P.S. Your new screenshot still illegible
