9 years agoProblems downloading to NIOS II / Verification fails
Hello I am trying to interface the SD RAM on a DE0 board to a NIOS II. I have carefully followed the steps required to set up the SD RAM controller to use the IS42S16400J. Unfortunately when I...
9 years agoHmm...
The device that appears after project upgrading is 5CGXFC7C7F23C8, which is Cyclone V ... not Cyclone III. This .csv pin assignment file you exported from your project ... or it was just present in your board package. --- Quote Start --- I wasn't able to get a single screen shot, but I can upload several if needed. --- Quote End --- How did you proceed with snapshot ? What OS are you using ?
