9 years agoProblems downloading to NIOS II / Verification fails
Hello I am trying to interface the SD RAM on a DE0 board to a NIOS II. I have carefully followed the steps required to set up the SD RAM controller to use the IS42S16400J. Unfortunately when I...
9 years agoHi Pavel
I have attached a zip file containing a csv for the pin assignments. I wasn't able to get a single screen shot, but I can upload several if needed. The device I'm using is a Cyclone III EP3C16F484C6 on a DE0 board. I'll compare your snapshot of you qsys filewhen I get home and let you know if I spot any differences. Thanks Andrew
