9 years agoProblems downloading to NIOS II / Verification fails
Hello I am trying to interface the SD RAM on a DE0 board to a NIOS II. I have carefully followed the steps required to set up the SD RAM controller to use the IS42S16400J. Unfortunately when I...
9 years agoHello Andrew,
Unfortunately I couldn't properly upgrade your project to my Altera Quartus Prime 15.1. Nevertheless I could open .qsys file. Here it: snapshot below. BTW, I didn't understand why you couldn't make image larger - simple screenshot grabber can do this job. Can you compare with yours: are there differences ? Other observations:- Qsys says that alt_pll doesn't support your Cyclon V device. Why not use simple PLL module from "Basic Functions"/"PLL"/"Altera PLL" ?
- I couldn't find wrapping top module (Verilog or VHDL) where you instantiate your qsys
- Also pin assignment is empty ... probably caused by problems during upgrade. Can you attach snapshot with pin assignment ?
