9 years agoProblems downloading to NIOS II / Verification fails
Hello I am trying to interface the SD RAM on a DE0 board to a NIOS II. I have carefully followed the steps required to set up the SD RAM controller to use the IS42S16400J. Unfortunately when I...
9 years ago --- Quote Start --- Your images are too small, can you upload larger ones --- Quote End --- Hi Pavel_47 Thank you for your reply. I have a link to my project https://www.dropbox.com/s/25kvh33zp6fc7s4/ehmcsys%20%282%29.zip?dl=0 if that helps. The images are screen shots fro quartus, and coocox so I can't make them any larger. Kind regards Andrew
