16 years agoproblems creating application and BSP from template
Hi, I am using quartus 9.1, I am trying to produce a projecting useing the creating application and BSP from template. I get the error Failed to execute: ./create-this-app --no-make chmod...
14 years agoYes, also working on Windows 7 64bit :
If you don't see a NiosII menu item on Eclipse, or File => Run -> Nios II C/C++ Application and BSP from Template Un-install all Altera packages, delete all Altera files, reboot, re-install NiosII with Eclipse. Then one should have the NiosII menu items, including "Nios II C/C++ Application and BSP from Template". If get a .bsp but no application : Run Eclipse in XP sp2 compatibility mode. I have administrator privileges. Say yes if get a run confirm window. Then run "Nios II C/C++ Application and BSP from Template". Should now run through OK. Build Application (right click). Use NiosII => Quartus II Programmer menu item to connect to hardware, upload .sof file. Run application as NioII Hardware, making sure you refresh the USB connection if needed (on extreme right of window if pops up). Should now all run. Best of luck.
