16 years agoproblems creating application and BSP from template
Hi, I am using quartus 9.1, I am trying to produce a projecting useing the creating application and BSP from template. I get the error Failed to execute: ./create-this-app --no-make chmod...
16 years agoHi -
I'm treading the same ground now and experiencing the same "No Hardware Configuration" option with NIOS II Eclipse 9.1 SP2 tools. Has there been any update on this problem? Trying to run 9.1 SP2 on Windows 7 32 bit. Other that this specific issue, I've been having pretty good success. Also, any updates on 9.1 IDE "non-bootable EPCS flash file" issue you reported? As you said, leaving 9.1 largely unusable due to only a handful of issues. Thanks, Phil
