Ftiglius
7 years agoProblem writing .SOF plus .ELF files with NiosII ECLIPSE FLASH PROGRAMMER using quartus 18.0 : error 8 during flash writing
Hi to everyone! We need to flash Fpga configuration + NiosII software (to boot application "on place"). This method runs with older versions. Attempting to write SOF + ELF on flash (with common USB B...
Ftiglius
7 years agoThanks, Abr! Connection should be ok, as per device ack... I can work every time with NiosII Jtag from Eclipse for long debug sessions of developing software. The problem occours when I attempt to program Flash using Sof+Elf. First 2 steps runs fine (see "buono" on report window attached..).. sfter first 2 steps programmer fails with "8" code error... but connection seems valid. Msel could involves only Fpga boot mode... not during programming....
