14 years agoProblem with the Nios II 11.1sp2 Software Build Tools
Hello, I'm working with the Nios II for few weeks with this hardware and software: Terasic DE0 Nano Windows 7 64 Bit Altera Quartus 11.1 SP2 Nios II 11.1sp2 Software Build Tools for Ecl...
14 years agoI’m glad someone replied to this post, but there’s more going on here. I’ve had this issue (the “The system console model is invalid. Cannot launch.”) off and on since I switched to Q11. I’ve found a few things that seem to toggle the problem, but I’m currently stuck and none of my little tricks are able to get past this. Things that have worked in the past: a) Close/reopen Eclipse IDE. b) Delete/rebuild project (importing source files to new system). c) I have a clock in my qSys system that doesn’t come alive (by design) on startup. I found that I can’t attach the debugger before this clock comes up even though NIOS is running on a different clock.
But now I’ve worked my way into a corner it seems, and none of these fix the problem. The error message has no details in it pointing me to something I can go look at. I’m just trying blindly to find things that clear this issue. If anyone has any ideas, more input would be appreciated.
