9 years agoProblem with system ID
Hello, I am having a really weird problem. I have a design in the form of an .sof and .sopc file and some code which I have written to run on top of this. I am using the DE1-SoC board. Thi...
9 years agoHi,
Could you give a quick try by creating a simple hardware maybe some blinking LEDs to ensure the SOF file can be programmed into the device? Just ignore the software part for this experiment as if you have programmed the SOF successfully usually you will be able to see the system ID and timestamp.
