20 years agoproblem with NiosII IDE 5.1
Hi Everyone, I have installed NiosII IDE5.1, but when I compiled any project, the following errors occurred. c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: `: No...
20 years agoI have almost find the answer throught altera website.
The following if FYI. Problem Why do I receive the following errors when trying to compile my Nios II project: ../app_rules.mk:152: \: No such file or directory? Solution You may receive the following errors when compiling a Nios® II software project if the mount point for the Cygwin toolset is not specified properly. ------------------------------------------------------------- make -s all "X"which cygpath.exe 2> /dev/null`" was unexpected at this time. <Nios II install directory>/components/altera_hal/build/app_rules.mk:152: `: No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:152: "<Nios II install directory>"`: No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:152: /components/altera_hal/build/gnu_rules.mk: No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:156: ': No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:156: "<Nios II install directory>"`: No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:156: /components/altera_hal/build/gtf_rules.mk: No such file or directory make: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk'. Stop. Build completed ------------------------------------------------------------- If this error does occur you can specify the proper moint points by running the following three commands from a DOS prompt: mount <Quartus® II Install directory>\bin\cygwin\ / mount <Quartus II Install directory>\bin\cygwin\bin /usr/bin mount <Quartus II Install directory>\bin\cygwin\lib /usr/lib But when I run the mount command in niosII SDK, it told me that command not found... Anyone help? THanks a lot...
