14 years agoproblem with LCD Refreshing rate
Hello, I recently designed a model in Quartus which connects to a color LCD device and shows what ever is on the SRAM. I am using the NIOS processor to fill the RAM with the relevent Data (P...
14 years ago --- Quote Start --- I can't get the point. Probably I still don't understand what you want to do. Please clarify. - where your picture data is stored? on the sram addresses - how are you supposed to get this picture data?from an external vhdl model which reads from the sram and sends the pic according to the svreen protocol - do you want to use Nios for the transfer or not?only for the writing - is LCD actually seen as a sram or a more complex interface is required? I mean, if you write a sram address, the related pixel changes on the display? Or maybe a special protocol is involved for transferring the display image?special serial protocol...you can look at terasic's touch screen --- Quote End --- http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&no=213
