14 years agoproblem with LCD Refreshing rate
Hello, I recently designed a model in Quartus which connects to a color LCD device and shows what ever is on the SRAM. I am using the NIOS processor to fill the RAM with the relevent Data (P...
14 years agoI can't get the point. Probably I still don't understand what you want to do.
Please clarify. - where your picture data is stored? - how are you supposed to get this picture data? - do you want to use Nios for the transfer or not? - is LCD actually seen as a sram or a more complex interface is required? I mean, if you write a sram address, the related pixel changes on the display? Or maybe a special protocol is involved for transferring the display image?
