14 years agoproblem with LCD Refreshing rate
Hello, I recently designed a model in Quartus which connects to a color LCD device and shows what ever is on the SRAM. I am using the NIOS processor to fill the RAM with the relevent Data (P...
14 years agoI can't understand your concern with sram. You access sram like any other kind of memory.
e.g. you can use sram base address with IOWR/IORD for direct access; alternatively you can map C variables/buffers (or even an entire memory section) to sram physical addresses. Example: int * lcd_buffer = (int*)LCD_SRAM_BASE; for (i=0; i<num_of_pixels; i++) { lcd_buffer[i] = <your graphic data>; }
