9 years agoProblem with downloading of a NIOS II program
Hello, Here below - the screenshot resulting from my attempt to download and run a simple NIOS II program on my Terasic DE1 card. Any comments ? Thanks in advance. http://www.alter...
9 years ago --- Quote Start --- Yes unfortunately Rsync didn't finish the document. It's missing specific examples, but if you apply the steps shown in I/O timing in the first chapter (pages 14-22) it should give you a good start. --- Quote End --- I've worked through this document with attention and remade my constraints in .sdc file according to it (at least I believe that it is the case). Unfortunately I've still problems with timequest analysis. As the problems I've met, overpass the subject of the actual post, I've decided to create the new one, that better reflects the discussed issue. If you want to express your opinion on these timing analysis issues, here is the link to the new post https://alteraforum.com/forum/showthread.php?t=55369 Thanks in adavnce
