9 years agoProblem with downloading of a NIOS II program
Hello, Here below - the screenshot resulting from my attempt to download and run a simple NIOS II program on my Terasic DE1 card. Any comments ? Thanks in advance. http://www.alter...
9 years agoAnd I forgot to add... once you have fully constrained your design, you should check that the compiled project actually meets all the timing requirements. Timing failure will not generate an error in Quartus, but only a critical warning. If it doesn't meet your timing requirements, you can use Quartus' timing advisor to see what you can do to your project to fix the problem.
