9 years agoProblem with downloading of a NIOS II program
Hello, Here below - the screenshot resulting from my attempt to download and run a simple NIOS II program on my Terasic DE1 card. Any comments ? Thanks in advance. http://www.alter...
9 years agoIndeed, I've just tried another design, that uses SDRAM memory (instead of on-chip memory) and the issue repeated.
Here is Qsys screenshot of this design: https://www.alteraforum.com/forum/attachment.php?attachmentid=13367 Concerning timing constraints, compilation report didn't reveal any violation. Here they are: create_clock -name clk -period 20 [get_ports clk] create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck} set_input_delay -clock altera_reserved_tck -clock_fall 3 [get_ports altera_reserved_tdi] set_input_delay -clock altera_reserved_tck -clock_fall 3 [get_ports altera_reserved_tms] set_output_delay -clock altera_reserved_tck 3 [get_ports altera_reserved_tdo] derive_clock_uncertainty set_false_path -from [get_ports sw*] set_false_path -from [get_ports key*] set_false_path -from [get_ports sdram_dq*] set_false_path -from * -to [get_ports led*] set_false_path -from * -to [get_ports hex*] set_false_path -from * -to [get_ports sdram*] So, apparently, the issue with failed nios ii downloading is quite recurrent, and there is no any reliable remedy against it. Am I right ?
