15 years agoproblem wih jtag_uart in Nios when use SSRAM
Hello, I have created the project Nios + TSE + PIO + RS-232 + pll + jtag_uart + SSRAM. Reset vector and exception vector in SSRAM. Through the jtag_uart the Nios sends the statistical information ...
15 years ago --- Quote Start --- most likely there is something wrong with your byte enables. --- Quote End --- Dwesterg, Thanks to you for advice. I have checked up pin connection Nios interface to SSRAM pins, with byte enable there are no mistakes. In my first poct I wrote, that If instead of jtag_uart to use RS-232 for sends the statistical information, that in the terminal visible, what Nios + SSRAM to work. From this I draw a conclusion that SSRAM memory is connected to the Nios correctly.
