11 years agoProblem wid nios ii APIs
Hello all,
I'm using Quartus v13.1 on my DE2-70 board with the cyclone II fpga. I want to enable interrupts using toggle switches. It worked when using the Altera ehanced interrrupt API (#include"altera_avalon_pio_regs.h"), However I tried using the nios 2 API (because we have some tutorials using it ) and It does not seem to work. For eg: I tried using the functions such as : __builtin_wrctl(3, 2) and __builtin_wrctl(0, 1) to write into the ienable and status register respectively. When i read the ipending register (ipending = __builtin_rdctl(4)) it shows 0 . I also tried replacing it with the nios 2 macros without much success. Here is the code i used: #include <stdint.h> #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include "system.h" #include "nios2.h" volatile uint32_t *LED = (volatile uint32_t *) LEDS_BASE; /* Green leds base address*/ volatile uint32_t * slides = (volatile uint32_t *) 0x41000; /* slider switches base address*/ void toggle_isr() { int press; press = *(slides+3); /* read the switch edge capture register*/ //*(slides+3) = 0; /* clear the interrupt */ printf("Hello from Nios 3! \n"); while(1) { printf("Hello from Nios I4! \n"); if ((press & (1 << 1)) != 0) /* SW[1] */ { printf("Hello from Nios II! %d \n", *LED); if(*LED == 0xFF) *LED = 0; (*LED)++; usleep(100000); } } } void interrupt_handler(void) { int ipending, status; printf("Hi! \n"); NIOS2_READ_STATUS(status); printf("HhgfghfjhgfghfI! %d \n", status); NIOS2_READ_IPENDING(ipending); printf("Hello from Nios II! %d \n", ipending); //if (((ipending & (1 << 1))) != 0 ) // toggle switches is interrupt level 1 if (ipending != 0) // checking for enabled interrupts in general*/ { printf("Hello from Nios 2! %d \n", ipending); toggle_isr(); } // else, ignore the interrupt return; } int main() { *(slides+2) = 0x3; NIOS2_WRITE_IENABLE(0x2); NIOS2_WRITE_STATUS(1); /* enable Nios II interrupts*/ interrupt_handler(); return 0; } Is there a reason why it is not working (errors in the code above, obsolete functions …)?No RepliesBe the first to reply
