14 years agoProblem to add an off chip SSRAM
Hello, I have a problem when I want to add an off chip memory in my design. I have read a lot about this issue but I have not been able to find the solution to my problem. Let me explain it int...
14 years agoFirst of all, many thanks for your help :)
As for your message, I tie the global reset signal to VCC, but the SSRAM reset signal I do not know where I have to connect it. In the SSRAM section of the user guide, there is not any reset pin. In fact, with Quartus II 6.0 the SSRAM reset signal does not appear in SOPC symbol and everything works well. Where should I connect this signal in Quartus II 11.1? Anyway, there are signals such as ssram_adv_n or ssram_adsp_n which do not appear in the SOPC symbol. I would like to tie them to VCC like in my design with Quartus II 6.0, but with the version 11.1 I am unable to do it because they do not appear in pin planner even thought I define pins with those names. How could I solve this issue? Any tip is welcome ;) Sorry if my problem is quite basic but I am not used to working with the last version of Quartus II. Many thanks!
