17 years agoproblem generating .sof file
Hello all !!
I am using DE2_NIOS_HOST_MOUSE_VGA project which came with DE2 board. I am using 9.0 version. When opening the SOPC builder is says an error "Error: ISP1362.avalon_slave_1_irq: associatedAddressablePoint out of range" when I delete the ISP1362 component from the added library .. the error goes but when compiling it gives a lot of error - Error: Port "OTG_ADDR_from_the_ISP1362" does not exist in macrofunction "u0" Error: Port "OTG_CS_N_from_the_ISP1362" does not exist in macrofunction "u0" Error: Port "OTG_DATA_to_and_from_the_ISP1362" does not exist in macrofunction "u0" Error: Port "OTG_INT0_to_the_ISP1362" does not exist in macrofunction "u0" Error: Port "OTG_INT1_to_the_ISP1362" does not exist in macrofunction "u0" Error: Port "OTG_RD_N_from_the_ISP1362" does not exist in macrofunction "u0" Error: Port "OTG_RST_N_from_the_ISP1362" does not exist in macrofunction "u0" Error: Port "OTG_WR_N_from_the_ISP1362" does not exist in macrofunction "u0" Error: Quartus II Analysis & Synthesis was unsuccessful. 8 errors, 68 warnings Error: Peak virtual memory: 275 megabytes Error: Processing ended: Sun Sep 06 00:48:17 2009 Error: Elapsed time: 00:00:25 Error: Total CPU time (on all processors): 00:00:26 I am trying to build .sof file which I can use later for configuring uClinux on DE2 board.3 Replies
I have also encountered the same problem, what you do to solve this problem. How to solvethis problem? Can you tell me? Thanks! !
did anybody solve this problem yet?
I have also encountered the same problem,did anybody solve this problem yet?
