14 years agoProblem for Downlading ELF
i request your help for helping me to fix a bug. i can't use the Run'as hardware feature since three weeks now. Before this time i have make little démo but now nothing since to works. the IDE of altera report me two error when i launch Run'as harware here is the first in the console box : http://sega4ever.power-heberg.com/FPGA/Altera%20error%201.png and here is the second at the end of Run'as test: http://sega4ever.power-heberg.com/FPGA/Altera%20error%202.png I use a Nios II F with Reset vector to EPCS Flash adress 0x0 and exceeption vector to SDRAM in 0x20. my custom Sram timing is 100 for delay and 70,20 for duration. i can't send you more image and do more test if you want to help me. Thanks !1 Reply
Does your project path contain a space by any chance? This happens for example if it is somewhere in "Documents and Settings". In that case move your project elsewhere, in a folder whose name doesn't have any space.
