14 years agoProblem creating a new project with existing source code.
Hello i am using NIOS2 SBT 11.0sp1 and i am trying make a new project with existing source code. When i select new project & bsp from template choosing hello world everything compiles and work. ...
14 years agoPlease refer to Nios II Developer's Handbook, page 6-37 and following,
namely the section named "Boot Sequence and Entry Point". alt_main() is the standard entry point for a raw Nios application, while main() is the entry point for a HAL based application. In the latter, an alt_main function is automatically generated which provides system initialization and calls your application main(). If you don't use any template, you must define the entry point function: void alt_main(void)
