Chloé_Russell's avatar
Chloé_Russell
7 years ago
Printing 32bit signed long data alt_32
I'm trying to print out returned alt_32 data from functions defined in drivers via the JTAG UART in a Nios II system. Execuse me for being newbie on this, here are my code lines:
alt_32 ret_code;
ret_code = altera_epcq_controller_init ("/dev/epcq_controller_0");
printf("ret_code = %x \n", (unsigned int) ret_code);
it returns an hexa value but I need to print out the following format:
-EINVAL
-EIO
Thank you for telling me what I suppose to write for printing out the alt_32 data.
  • JOHI's avatar
    JOHI
    The only solution is do something like
    #include "ErrNo.h"
    if (ret_code == EIO) printf("EIO");
    EIO is a symbol that is defined in one of the header files. (ERRNO.H)
    The preprocessor replaces EIO with a decimal or hex value of 5 before compiling.
    See below an extract of the file:
    * Error numbers.
    * TODO: Can't be sure of some of these assignments, I guessed from the
    * names given by strerror and the defines in the Cygnus errno.h. A lot
    * of the names from the Cygnus errno.h are not represented, and a few
    * of the descriptions returned by strerror do not obviously match
    * their error naming.
    #define EPERM 1 /* Operation not permitted */
    #define ENOFILE 2 /* No such file or directory */
    #define ENOENT 2
    #define ESRCH 3 /* No such process */
    #define EINTR 4 /* Interrupted function call */
    #define EIO 5 /* Input/output error */
    #define ENXIO 6 /* No such device or address */
    #define E2BIG 7 /* Arg list too long */
    #define ENOEXEC 8 /* Exec format error */
    #define EBADF 9 /* Bad file descriptor */
    #define ECHILD 10 /* No child processes */
    #define EAGAIN 11 /* Resource temporarily unavailable */
    #define ENOMEM 12 /* Not enough space */
    #define EACCES 13 /* Permission denied */
    #define EFAULT 14 /* Bad address */
    /* 15 - Unknown Error */
    Johi.
  • Hi JOHI,
    Thank you for your reply, this helped me too much..
    Best regards
    CR
