8 years agoPreloader Make untar failing.
I am attempting to compile a new preloader on windows using SOCEDS 18.0...but am failing at untar'ing the uboot-socfpga.tar.gz. Chris@DESKTOP-NSSUV7O /cygdrive/f/VirtualBox VMs/share/rocket...
Julien
8 years agoHi,
I stumbled upon the exact same issue, Quartus 18.0 & Windows 10 here.
MKami1 answer nailed it, however personnally I did not want to delete c:\windows\system32\tar.exe from my system, so instead I opted for a one line modification of the Makefile, to avoid swapping windows-style paths by unix-style paths for this specific command:
#$(UNTAR) $(shell cygpath --unix "$(if $1,$1,$(if $<,$<,$(error ERROR: no input provided to gnu make function untar_recipe)))")
$(UNTAR) $(if $1,$1,$(if $<,$<,$(error ERROR: no input provided to gnu make function untar_recipe)))
Works fine. There is probably a much better permanent fix, but I will let Altera care about it.
Cheers
Julien
- AThap37 years ago
Worked for me!
