20 years agoport goahead web server to nios2 uclinux
hi all: I ported goahead websrver to nio2 use hippo's toolschain. GoAhead WebServer 2.1 is a fully-featured, open-source embedded Web server that leverages Active Server Pages, embedded JavaScr...
20 years agoHi alex,I followed your steps to port the webserver.When I arrived the 10) step,I met the following err:
[w@localhost w]$ cd uClinux-dist-test [w@localhost uClinux-dist-test]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux- uclibc- make -C tools/ucfront make[1]: Entering directory `/home/w/uClinux-dist-test/tools/ucfront' make[1]: Nothing to be done for `all'. make[1]: Leaving directory `/home/w/uClinux-dist-test/tools/ucfront' ... ... ... ... ... ... [ -d /home/w/uClinux-dist-test/images ] || mkdir -p /home/w/uClinux-dist-test/im ages cp /home/w/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/boot/zImage /home/w/uCl inux-dist-test/images/zImage make[2]: Leaving directory `/home/w/uClinux-dist-test/vendors/Altera/nios2nommu' make[1]: Leaving directory `/home/w/uClinux-dist-test/vendors' [w@localhost uClinux-dist-test]$ nios2-linux-uclibc-strip vmlinux nios2-linux-uclibc-strip: 'vmlinux': No such file Then I do it by the following way,but I do not know if it is correct.Could you tell me what does the command "nios2-linux-uclibc-strip" mean? [w@localhost uClinux-dist-test]$ nios2-linux-uclibc-strip images/zImage [w@localhost uClinux-dist-test]$
