20 years agoport goahead web server to nios2 uclinux
hi all: I ported goahead websrver to nio2 use hippo's toolschain. GoAhead WebServer 2.1 is a fully-featured, open-source embedded Web server that leverages Active Server Pages, embedded JavaScr...
20 years ago --- Quote Start --- originally posted by mfm@Apr 5 2006, 02:05 PM <div class='quotetop'>quote
--- quote end ---
--- quote start ---
i ported goahead websrver to nio2 use hippo's toolschain. --- Quote End --- Hi, can you help in doing the same but under the IDE ? Warm Regards <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14072)</div> [/b] --- Quote End --- Hi MFM: If you want to use goahead webserver in nios2 linux, you must use toolchains cross compile it. The IDE is difficult to compile it. I think the best way is build your nios2 toolchains under linux.
