9 years agoPointer access from qsys custom component
Hello
My nios code is running on a DDR I have also a custom component connected to the DDR The purpose is to define a pointer register in DDR and to overwrite its value from the custom component through its avalon mm bus So, if i define a pointer on the c code . lets assume its address will be 0x800. Which address should be used on the avalon mm bus of the custom component in order to do that ? Thanks in advanceNo RepliesBe the first to reply
