14 years agoplz help me with this problem(build C2H project)....
Hi all, I'm new here. recently,i was trying to test the C2H Compiler. But after i build the target project, i met an error as follows: <--------------------------------------------------...
14 years ago --- Quote Start --- I'm suspecting a file/directory permission problem. The error is saying that it cannot write the system .ptf file to your file system (i.e. it dropped the accelerator into your design but can't save your system before generating it). It might also be the hyphon (-) in your directory path causing problems. Try turning that into an underscore (_) instead and see if that fixes the problem. --- Quote End --- <--------------------------------------------------------------------> thanks for your reply, i have changed my file/directory and there is no hyphon(-)in my directory path..but still failed. It was strange that i met a new error as follows: --- Quote Start --- Progress: Loading system from fileD:/c2h/nios.sopc... Exception in thread "main" java.lang.NullPointerException at com.altera.sopceditor.util.EditorUtils.setQuartusProjectInfo(EditorUtils.java:2089) at com.altera.c2h.C2HGenerate.createEnsemble(C2HGenerate.java:138) at com.altera.sopceditor.app.EnsembleApp.start(EnsembleApp.java:171) at com.altera.c2h.C2HGenerate.main(C2HGenerate.java:79) make: *** [c2h_hdl-t] Error 1 Build completed in 22.344 seconds --- Quote End --- <-----------------------------------------------------------------------> Meanwhile, i noticed that there is a similar error in "Nios II Embedded Design Suite Release Notes and Errata" like this: --- Quote Start --- Exception in thread "main" java.lang.OutOfMemoryError: Java heap space make: *** [c2h_hdl-t] Error 1 --- Quote End --- i faint...it really drives me crazy.....what should i do?:(
