14 years agoplz help me with this problem(build C2H project)....
Hi all, I'm new here. recently,i was trying to test the C2H Compiler. But after i build the target project, i met an error as follows: <--------------------------------------------------...
14 years agoI'm suspecting a file/directory permission problem. The error is saying that it cannot write the system .ptf file to your file system (i.e. it dropped the accelerator into your design but can't save your system before generating it).
It might also be the hyphon (-) in your directory path causing problems. Try turning that into an underscore (_) instead and see if that fixes the problem.
