15 years agoPlease help me ......SDRAM DE2
:( i have a problem.....my project need to use sdram on de2 board altera...but i dont know to use sdram......some master help me.... i use sopc to configure a sdram controler on my system...... ...
14 years agosystem:
De0 - SDRAM (A3V64S40ETP G6); Quartus II 11sp1; QSYS; Nios II EDS (eclipse). The lack of parameterization in the memories is a common flaw found in the Terasic kits. The realization of this is visible when looking up the forum for answers from Altera. I'm trying to implement a simple Nios II SDRAM to have a little more memory. I tried with the parameters of the "Embedded Peripherals IP User Guide", but nothing works. The frequency used in PLL as setting 50 MHz (20 ns) because Tac = 17ns. I tried to set it to 100MHz (Ph-3rd) according to the datasheet "A3V64S40ETP G6", but has problems of ELF. I found many settings that were placed without concern for a frequency of operation and specification of memory. So, I would like the configuration parameters of the SDRAM. SERENETY NOW!!!!
