15 years agoPlease help me ......SDRAM DE2
:( i have a problem.....my project need to use sdram on de2 board altera...but i dont know to use sdram......some master help me.... i use sopc to configure a sdram controler on my system...... ...
15 years agoThank you, primiato and socrates.......i think i was success building my system with sopc buider and i allso use PLL to create dependen clock for sdram controler block....
but i mean how can i use languge c to access into sdram controler....... i saw all examlple use verilog HDL to do that......anđ as primiato said to me that "do you want to read/write it from a custom ip/design you are developing or do you want to access it from a nios softcore?" so i think i want to access it from a custom IP.....because of your advice:-P if you dont mind you can teach to me about "custom ip/design"... i really need that because :cry:my project have to finish last month... thank evey body so much......
