14 years agoPeriodL & PeriodH
I understand that timeout period determines the period of your interrupt. I also understand that periodL and periodH is holds the LSB and MSB 16bit value of the period register. My question is...
14 years agoIt seems strange to me that Altera haven't supplied 32bit versions of the timer devices. I presume the 16bit versions have been carried forwards from an earlier design - It isn't as though a 32bit version would be difficult to write from scratch!
It is worth checking that you don't need to subtract 1 from the count - check the datasheet/pdf.
