15 years agoPCIe device disconnect/disable needed to reprogram FPGA
I am using the Altera Stratix IV dev kit. The FPGA is in a PCIe slot on a system running Linux. Is there a way (i.e., some Linux commands or some other method) for me to be able to disconnect/disab...
14 years agoHi!
I am are facing the same issue. When I reprogram my Stratix IV 530, the kernel panics about an NMI and reboots... Did you find a software workaround, i.e is there a way to disconnect/disable the endpoint before reprogramming the FPGA? Also, is this issue server-dependent? I.e. are there some servers (or more precisely some motherboards, I think...) that simply do not allow to do this kind of stuff? Thx Julien
