9 years agoPC doesn't receive packets from Nios II
Hi, I need to send data from de2-115 to PC using triple speed ethernet core, and then process the data using a program which I wrote using Qt. I manage to make it work sending the data to the pc. Wireshark show the data arrive but with bad frame check sequence. I think it's the reason why the program couldn't read the packets. Anyone has any idea to fix this?
Here is my code for my udp ethernet.No RepliesBe the first to reply
