15 years agopausing target processor: not responding
hi all, i hav build a system in sopc builder using nios ii cpu, jtag_uart, esps_flash_controller, ddr_high_performance_memory_controller, tse_mac, sgdma_rx, sgdma_tx, flash_tristate_bridge, ext_f...
15 years ago --- Quote Start --- and for toggling LED where i should write code, in nios or in quartus. . .?? --- Quote End --- In Nios program. Say you have a spare PIO port named led_out, possibly connected to LEDs. Then you can toggle the first pin by calling periodically this function:
# include "altera_avalon_pio_regs.h"
void PIO_pin_toggle(void)
alt_u8 pio;
pio = IORD_ALTERA_AVALON_PIO_DATA(LED_OUT_BASE);
IOWR_ALTERA_AVALON_PIO_DATA(LED_OUT_BASE, pio ^ 1);
} This way you can easily monitor if your Nios program starts, keep running or hangs at some time. Regards Cris
